Chris King Help Please
BenLeacock™
right basicaly my king blew up, the spring is f**ked, so im going to order a new spring, but the spring capture plate is also pritty f**ked, theres a little bit that runs around that looks like a seel that is all over the place ... :S do i need a new one or will this be ok? thing its been completly battered before i got it ?
Is there anywere that sells capture plates ?
Ben
Ben
Get in touch with Grant Hundley. He's f**ked his King up in what sounds to be a similar way so should be able to give you some help.
He stretched his spring like a m'f'er though, don't suppose you're as much of a tit as him though?
As for spares, I'm pretty sure Dan @ Trials-UK can order in whatever spares you require.
Same with anywhere that stocks Kings though I should imagine.
Edited by Shaun H
Its all sorted, thanks... what i think had happeend is when its been put back together the drive and driven rings havent been put in properly and havent been siting straight... I think ive sorted it :P
How tall are you?
erm 6ft 8-9 havent actualy measured myself for a while... ill do it now for you inur :P
edit: 6ft 8, 2cm off 6ft 9 :)
Edited by BenLeacock
Ben i've just thought. They say front the tip of your fingers on your left hand to the one's on your right hand with your arms streched open is the same length as your body :blink: You must have long f**king arms !
Danny.
Edited by Danny Kearns
Danny.
Not the case. Some people have that ratio, but a lot of people don't. We even did an experiment on it in our math's class in year 7, there was a pretty even spread between armspan > height, armspan = height, and armspan < height.
