Onza Zoot Seat
Could you put a normal saddle on?
Yeah, pretty sure it's just a 27.2mm (:-) seat tube you end up with so any BMX size post will fit in there. It's just a flat plate that bolts into the 4 threaded holes on the bridge between the seat stays and then a tube welded to accept the seat/post. The seatpost itself will then slide through the porcupine shaped hole in the bridge if you get me.
Why's everyone hate having a seat?
Thanks for replys.
How did you manage to cut your finger on it? Did you put your finger in then push the bike away as faast as you could?
i lifted it up to put it on the bike rack by the hole, and cut it!! i dont mind having a seat, i would on an inspired, just on an onza zoot it looks whey ghey......
Yeah, it's not a hate of seats- just on the Zoot frame the design just doesn't lend itself to having a seat and post sticking out of it. Only really 'works' on proper double triangle type frames in my opinion.
seats are cool, especially when they are done up abit, they can virtually fly
