Hs33 Hosing
SkiLLz
Right i dont want to clog up the forum so im to post in here, im thinking of getting some clear hosing aswell, i want to use a water bleed as i find there better than oli, will i be able to put die into the water when im bleeding it ? or will it F up the seals ?
used food colouring in mine, not to produce a strong colour, just to make seeing air bubbles easier. but it never damaged it in like 18 months of use. cant see that theres much in food colouring thats gunna rot the seals.
