What Parts Would Make My Zona Zip Lighter?
Lewis-Trials
Hi i was just wondering what i could buy to make my Zona Zip lighter at the back, Isit the tyres that are heavy i dont know.Whats everyone's ideas. Ive got some standard tyres on the back at the moment but wanting to change if its the problem? Ive got Ronnie & Reggie set, dont know what tube and dont know what tyre?
Zona Zip 20" Frame. Grey aluminium alloy with green detail.
Magura HS33 Black hydraulic rim brakes. Fitted with magura 4 bolt mounts.
Onza Alloy Forks
Onza muscleman Crankset, 18 tooth freewheel and Onza Double Caged Pedals
Onza Reggie and Ronnie drilled rims hand built onto sealed bearing Onza alloy hubs with Cro-mo axles.
Some new cranks like Echo Forged or CNC should shave off 100 grams. Some flat Magnesium pedals like MG1s should get another 80 grams off. Plus a light BB like Try-All/ Meta/ Trialtech might eliminate a bit more weight depending on what your currently running?
If you on a KHE Collapse chain, try a KMC 510HX.
I wouldn't bother with tube changing. Try a Creepy Crawler tyre and remove some nobbles with a Stanley knife. That will kill a very noticeable 100 grams. Allot of people are doing that now. I however aren't bothered about it right now.
Maybe a lighter complete rear wheel later?
Alloy snail cams instead of chain tugs.
Hopefully that should give some idea how to remove weight from the rear of the bike.
zip frames are tanks, heavy but indestructable...
and yeah if you want light get rid of all the onza bits.
Yeah eventually i will but ive just bought the bike and owe people money sp when i get that payed off i will buy parts but its if i can get good bargains of here for some forks and bits.
