What Brake Set Up Do You Use?
Hallett
Just curious how people run ther brakes and how they have set them up.
everything from grinds to pads to what fluid you use?
My setup:
FRONT
In summer i use
Brake: HS-33 racelines
Pads: Rock green
Rim: Smooth rim
In winter i use a magura louise disc
REAR
Pads: Rock blues
Rim: Medium grind
I am currently using original factory brake fluid as the racelines are new.
but once they need bleeding i will use water!
post back with your set up
x
Edited by Pooch
Front and Rear 200mm Hope mono trials ;)
Well, i used to. Going to be using an avid ultimate with inspired vee pads and a smooth rhyno lite on the new beastie, and probably putting on a smaller front rotor.
Edited by Skoze
Well, i ride two bikes. I have a dual disc for competitions, it has front and rear try-all brakes.
And for street and some natural, front onza disc, really sharp with avid lever. and rear magura hs33 with light grind and plaz crm pads.
front onza disc? whats that ive never seen him
I use, hope 180mm on the front
and i chop and change brake pads between heatsink and rock, seem to both be good on a light/medium grind, in bad ass cnc backings
24" bike:
front hope mono trial 180mm
back new style magura hs33 with green rock pads on a pretty dead grind (works really well)
26" bike:
front un-branded vee brake with crap standard pads (will be changed soon)
back new style magura hs33 with black magura pads on very light grind (will be changed soon)
FRONT
Brake: Hayes nine
Pads: Hayes
Rim: try-all fluro green (disc wheel)
REAR
Brake: HS-33 04 red
Pads: onza limes
Rim: Medium grind
Are Onza limes any good thinking of geting some.
I ride:
FRONT.
Tecktro V-brake with Avid leaver.
BACK.
04 Hs33 with maggie brown pads.
I ride:
FRONT.
BACK.
No not really, although stu will try tell you otherwise, i've been using koxx reds on my rear maggy only for a short time (now gone dual disk),
They worked really nicely, not much modulation but lots of hold and good bite.
soon to report on dual disk set up, but my front BB5 is far better than any BB7 i've used.
