Creaking Bike
Bol Maaaaaaing
My bike has decided it wants to creak and groan a lot now.
I think its the cranks or the BB, its not the spokes because they are real tight.
When I bounce on the back wheel or put sudden pressure downward on the bike it does it.
What could it be and how can I fix it?
Wanna get it corrected before it ruins my bike
Take your cranks, bb and pedals off then, clean the lot grease it up and pop it all back together. Bob should be your uncle.
If you think it may be coming from the BB area you can do a series of checks to eliminate all the possibilities of noises.
Could be four things.
Pedals - Are they loose?, as in the axle itself or the bearings?, are an pins loose? get an old pair of pedals and put them on, if the noise has gone, problem solved.
Cranks - Again, are they loose? ensure they are tight and apply some copper grease to the tapers (especially on square taper where the dry metal on metal can bring up a creaking noise).
Chain - Is it too tight or too loose? a tight chain can make some horrible noises when moving, similarly a dry chain can make horrible noises, give a good spraying of WD40 to get it well greased.
Bottom bracket - Is it loose? make sure by trying to tighten it, has a bearing gone? you will only know if none of the above work.
If it creaks around the bb/crank area whilst you're pedalling check your bb cup, if it's a plastic cup then it might be cracked. Replace it and that should sort out the creaking problem once you put it all back together as that was a problem that mine came up. I just replaced it with a metal one sorted it out.
