Attaching Disc Onto Hub
Why are there specific rotor bolts used for attaching discs to hubs? Reason I ask is that I'm converting to front disc and at the moment I have attached the disc using two rotor bolts and four allen key bolts as that is all I could find. Is this ok or should I go out and buy some rotor bolts?
Edited by matt-richardson
Rotor bolts would be best.
Torx bolts are shite if you ask me, the head strip out really easily, and they they're flat on top so you can't get the out easily.
I use Stainless allen key bolts, not sure what grade, but they're strong enough to pull all the threads out of the hub before they snap!
Yes i agree, Im a cycle mechanic and there is not alot of differnce from rotor bolts than normal allan key bolts, If i was you i would just got for a normal allan key bolt which is not aluminium as you said .
All hope brakes used to come supplied with allen screws (screws not bolts ;) ), they were low profile cap heads so they would clear the caliper on smaller rotors. Im not entirely sure why they all use torx screws now as there is no really high torque requirement on them and its just a pain in the arse to have a torx driver aswell. I use allen screws on all of my disk brakes.
Edited by forteh
The propper jobs will have been tested to cope with the high shear stresses.
Normal bolts will do, but get some good quality stainless steel ones. Try a chandlery for quality bolts, not B&Q.
Stainless steel is weaker than normal steel ;)
Most 'blacked' allen screws will be grade 12.9, more than plenty strong enough :)
For more info see here
All depends on grades.
Typically the strongest stainless fastener you can buy is an A4-80 which has a uts of 800 MPa, now compare that to the 1200 MPa of a standard black allen screw. Also bear in mind that 90% of the stainless fasteners you buy (especially in the sizes common to bikes) will be A2-70, weaker still.
Muel, you probably ground them down to make them lighter.
My torx bolts are fine, they came with my disc.
Errm, no? I'm clearly bothered about weight these days, using stainless steel bolts over TI/aluminium ones...
My bike weighs over 10kg, I'm not bothered by numbers any more as long as it isn't a tank. The only modification to mine was I drilled the sidewalls because it was too heavy towards the front and I wanted to find out how much I could save.
The torx ones would be lighter anyway? I just really hate them, I had so much trouble getting one out for my mate once after he stripped the head. An allen bolt wouldn't have stripped anyway, and if it had they have a square head instead of a dome, so you can easily file a flat on either side and get it off with a pair of mole grips.
I was joking..
