Which Way Does The Drive Side Of A Bb Tighten Up
mountian goat
Would'nt it be clockwise? because as you pedal your cranks go clockwise so it would help tighten the bb...where as the other way would eventually losen it. I may be wrong, I can never remember which way it tightens.
Edited by Dave!
No.
Drive side tightens anti clockwise, non-drive tightens clockwise (standard way)
However with pedals, non-drive tightens anti clockwise, and drive tightens clockwise ;)
Fun times. The way I remember pedals is always turn towards the front wheel. BB is therefore always turn towards the back wheel :)
The way that I remember is that if you need to get a bb out when the bike is upside down, you turn the spanner towards the wheel (either side).
Unfortunately:
A bike has two wheels, and, depending on where the spanner is, either way is towards any given wheel.
righty tighty
lefty lucie ;)
Did you not even read two posts above, that is completely irrelevant as it reverse thread.
So going by that rule, righty would be loosey, and lefty would be tighty.
If you can't look at a thread and work out which way it turns you don't deserve to own the tools to remove/fit it.
What if its already fitted and you can't remember which way loosens...?
The easiest way to remember how to unscrew both pedals anad BB's is that if the bearings seize and you continue to pedal forwards, the BB and the pedals on both sides all come loose. This is not the reason they're made this way though - it's all down to torque free precession...
So, the real question is why is the drive side of the bb reverse thread.
So it tightens as you pedal, despite looking the opposite way, the fact that its a something rotating within a bearing, the small amount of force on the outside of the bearing will be going the opposite way to rotation. at least thats how I had it explained to me many moons ago.
Sorry to be harsh though...
na its ok
never really thought about that :$
come on its the first time i have ever fitted a bottom bracket
but thats no excuse for my dumness :P
