How To Strengthen Grinds?
J Trials 31
So I can't get a hold of a grinder right now and my pads are slipping a bit. Any way to renew my grind without actually putting a new one on?
Just leave it or sometimes what i do is get a hack saw and cut round the rim lightly its like a grind and works ok
what pads are you running ?
I'd say use tar till you get a new grind. :-
Well yea if you want a horrible sticking feel ever time you pull the brake in then yea use tar.
Using either Echo or Zhi rim. Can't remember which lol. Think it's an Echo. And rear pads are Heatsink clear's ( they are clear not sure what they are as obviously they don't produce them anymore) Anyway might try the hacksaw deal. Tried the wire brush and it worked for a while, but the way I ride only like 3 days. Also, does Dremel make an attachment or is their a small handheld grinder that I could get that would work a lot easier? In the future anyway.
