Trialtech Forks
liam1992
I thought all front hubs were 10mm axles?
International standard for MTBs is 9mm (which is what the Trialtechs are). The Echo bolts are 10mm which is where the issue lies...
In the past we have seen people remove a bit of meat from the dropouts on the fork, that worked perfectly. As long as it's neat it won't void the warranty either, Dave is aware of the problems with Echo hubs and understands that it may need to be done.
I don't see how they can't fit. I thought all front hubs were 10mm axles?
Well the hub was from tarty but it was about a year ago so that could be why ?
so my only option is to take a bit for the metal off of the drop outs ??
Edited by liam1992
Yes, 0.5mm each side - or a new hub.
If this man says something you do it.
I'd mod the hub myself, seeing as the fork's worth more n all.
The bolts that thread into the hub are 10mm so unless you don't want threads on your hub mod the forks.
