Will Onza T Bird Cranks Fit A Czar Mod Frame
Dave Sutton
That issue would be solved with a longer BB, which might be cheaper than those cranks.
im abit confussed with what that has to do with the topic?
that isnt a czar frame and there not onza cranks :S
the onza cranks will fit the czar frame if you have a square taper bb that is long enough?
They will fit if your existing bottom bracket is wide enough to allow them to clear the chainstay. Otherwise a longer BB will be needed.
+1 (Y)
the picture is an example of a chunk being taken out of the frame, its my mates
The point is, he can probably avoid what has happened in the picture and avoid buying cranks by buying a longer BB.
Get it?
Here is the proof -
Onza t-bird crankset - £40
Trialtech Race Square Taper BB, £12
So, if he's wanting the t-bird cranks, he must have a square taper BB already. So, he must have square taper cranks already. Therefore, if he spends £12 on a looooooooong BB that will cause his current cranks to clear the frame, he's avoided spending another £28 on cranks that might not necessarily solve the problem.
:D I win.
Edited by Revolver
