Modstock
isitafox
Modstocks are a bit shit IMO. You have a skinny hub, so a less stable wheel build, and a big rim, so a more flexible wheel, these add up to a very flappy wheel.
There are 135mm hubs available now with much wider spaced flanges than normal, and 135mm horizontal frames, which is the best wheel/frame combo if you ask me.
That was a lot of people's beef with modstock frames when they first came about, but it's still not true.
Echo 20" fixed rear hub flange spacing at the time was 2-3mm WIDER than a 135mm King SS hub.
That's not true my friend, apart from having to get a different hub these frames have little to no downsides. But why Deng had to make horizontal dropout stock bikes with a 116mm hub is beyond me.
  • Like 1
