Best Front Rim?
Si whitby
Aren't you running a Hope Pro 2 hub on the front Si? Get a lighter front hub and as Nick has said a TT or a Rockman/Try-all hole front rim. Saying that Joe is loving his Dob rims, but then he is a smidge smoother than you :P
I've got a spare king disc hub so was thinking of using that and keeping the other wheel built in case I want to go back to HS33s.
To be honest mate i'd sell your King hub it's not overly light for a front disc hub, fine for an MTB but if you're wanting a nice light front wheel it won't help. Get an Echo TR hub or see if you can find a cheap Try-all disc hub.
the eyelets are at such and angle, when the spokes leave the nipple they have quite a sharp bend in them meaning they will snap easier. Well that's for the rear ones anyway.
well he wants a front rim :P & my front elitis has been fine eyelet wise, so perhaps i wont get a rear when my onza dies.
As has been said, I would recomend either a try-all/Rockman hOle if you want something a little wider go for the trialtech!
I have the best front rim, but its a completely custom DX32 with large square holes, drilled sidewalls and single walled, weighs less than a try-all/rockman rim!
unless you ruin rims like me...
How do you ruin them though, for a trials rim there realy isn't much need for eyelets, I have not had a rear rim with eyelets for atleast 5 years now and never had a problem!
Adam
