Punchers !
BradJohnson
Hi all, im after some advice, in a week i've had 7 punchers, why is this happening, most of the time the punchers are opposite each other , do i need new tubes/tyres because im use innova tyres and tubes that cam on the bike when i bought it.
tyre pressure is rider preferance. im quite heavy, so i like a fairly high tyre pressure. a decent tyre (with a thick sidewall, like the try all sticky) will help prevent this, and thicker inner tubes will aswell :)^_^
i ride a stock ;)the tryall sticky is a mod i think "/ but i maybe wrong ?
Thats called a snakebite where the rim puts two cutings into the tube.
Whats bike is it? I've never heard of these tires. Upgrading them would probably be a good idea (Y)
Also just try riding smoother if you have a basher style.
They do it in stock sizing too, i have one. i run about 15psi and only get flattys if i proper rim it, although i would recomend that you run around 20-30psi probably.
i ride at 20-22 PSI ?
could it be my weight im about 5ft11 and i weigh 12 1/2 stone ?
I've just said i ride a stock ?
