Single Speed
onza1
Hi all
Broke my gears on me mad phase so need it to go single speed. The mech hanger is a bit bent will I need a new one and which one? Also thinkin of using the DMR single speed kit will it be ok ? what size rear sprocket shall I use will a 16t one be ok ?
Thanks in advance costing me £70 at the local bike shop to get it all fitted so hope it's worth it
Hi all
I did the same thing on my phase i went online to superstar components they have the sprockets i use a 20t but if i were you go for the 18t
its £10 for the sprockets and spacers, there brill too, i also bought the tensioner but a word of advise dont buy it, it doesnt work + you dont need it just take links out for your chain, its a bit tight but i works fine.
I also bought the cassette tool for £5 i fitted the single speed kit my self, i saved a lot of money and i have had no problems with it at all, it was a great buy.
Just priced it up on tartybikes and a trialtech spacer kit, sprocket, atomz tensioner and icetoolz lockring remover will cost you just over £45.
And if you've got a 22t front chainring then go for 18t on the back!
I can get it for £15 free postage too, and you can fit the your self, so no fitting fee.
This has gt me thinkin brad why does everyone recommend tensioners but you dnt does it ride ok ? Also what about these mech hanger things. Can't view tht superstar components on me iPod so will have to wait till tomorrow
I dont use a mech hanger too i just use two thick washers, and it rides perfect, heres a picture:
post-28186-0-24524500-1301861454_thumb.j
Think I'll do it like that
Any other recommendations welcome
Do you use a half link ? Also how comes noone else recommends this?
I dont use a half link i bought KMC white chain from ebay for a tenner, and i think no one recommends this because the chain is tight and people may think it will snap but ive had mine for 3 months now and its still fine.
post-28186-0-03950800-1301862155_thumb.j
Edited by bradjohnson
It's because not running a tensioner entirely depends on your exact setup. I used to be able to run no tensioner on my old Fourplay with 23:17 gearing, but on my new Fourplay with 23:15 gearing I have to run a tensioner. It's not just a case of "I don't want to run a tensioner so I'm taking it off" - it depends on your frame/gearing/chain. People don't really recommend half-links because cheap, rubbish ones that people seem to mainly buy snap. If you get a decent one they can last a reasonable length of time.
Spoke tensioner.best of both worlds? I just made one as i threaded the axle mount on my sts,which dmr replaced free i hasten to add, easy to make and really works,made mine first go as well.wasn't sure i'd trust it as seems to simple but had to ride before part turned up and not sure i'll change it back to the dmr tensioner now
Do you use rubber washers or metal washers ? Also do I just need a k type hanger ?
What happens if the chain is just a wee bit slack ?
I use metal washers, if the chains too slack it skips.
Yeah i think it is a k hanger.
What gear do you usually use for trials ?
