Eno Freewheel Not Cutting It = (
craigmatthews17
So i just went out for a ride and as suspected going from a 16t cassette cog to a 18t freewheel hasnt worked =( im peddling way too much!
it also slipped about 5 times , this maybe due to it being first ride.....
soo are there any good 16t freewheels??
If you're pedaling too much you need a smaller rear sprocket.
  • Like 1
The Eno freewheel has sealed bearings, and as they bed in they ooze grease onto the ratchet mechanism. If you take the lockring off your freewheel, you can clean out the pawls and springs and that'll get it working much better.
Not if you're running the freewheel on the back you don't ;).
A 22T chainring at the front is equivalent to standard 18:15 gearing which is used by pretty much everyone who rides 'proper' trials on stock. Stick with it and you'll get used to it.
so basically use the 22t and 18t freewheel as ile get used to it....
Yep. It doesn't sound like you've rode for long so you'll find learning the skills easier. Just gotta get used to it... and the fact it takes a lifetime to ride anywhere!
