Wheel Build.
bike_dummie
hi, going to build a wheel up for Christmas and have a few questions.
1.Is it possible to have a radial build (non-disc) on the right and 3x on the left(disc side)?
2.where can I buy quality Ti spokes?
3.what length will I need to purchase the Ti spokes if I use this hub and this rim on the non disc side built radial?
4.what is the thread size for the echo tr axle?
5. Ti rotor bolts are they any good (the hope ones)
Thanks Adam.
Edited by bike_dummie
3x isn't overkill at all, the hub will thank you for it too.
As said, don't bother with ti spokes, get some Sapin double butted instead.
The echo TR axle is an M6 thread.
Ti Rotor bolts are OK, make sure you use a good quality tool with them though to stop them rounding.
I think ill stick with 3x on the disc side if it is possible? I will scrap the idea of Ti spokes and stick with steel :).
Been thinking about doing some cut outs on the flanges sorta like the rockman disc/echo sl, what are your views on this, will it considerably weaken the disc flange?
