Bionic Frame Stiffness
onzatrip
Hey people, I'm running a bionic b5r frame with the set up is tnn clamps, phatpads in cnc with a 04 Maggie with a fresh products blade, the issue is without a booster the brake is very bitey but does slip sometimes but with a trialtech 2 bolt booster it loses all bite but holds like a bitch! What I'm wandering is thee some way which there could be an in-between ??
All help appreciated
Thanks
Tris
I had an Echo booster, made little difference and flexed a fair bit, if you want slightly more hold give one a go.
Want less hold with the trialtech booster held like a bitch but had no bite and other way round, this sl off mikey should do trick needed
