06 Pitbull
ghostrider88
spec list
06 zoo pitbull
2009 urbans
echo hifi stem
trieltech risers
crankbrothers cobalt headset,10mm carbon spacer
rockman foam grips
front wheel:echo urban hub,tt square holed rim,DT spokes,dt alu niples,conti speed king 2,1 supersonic
rear wheel:because hub,echo sl freewheel,urban front rim,dt spokes,dt alu niples,conti der kaiser
modified 175mm shimano slx cranks,21t actiontec ti chainring,modified tensile 20t bashring
front brake:saint lever,deore caliper,formula oro 203mm rotor
rear brake:deore calipers,avid sd 7 lever,rockman blues,some very light cnc booster(approx 60g with bolts)
kmc 510hx chain
Edited by ghostrider88
Ah i know the feeling, i miss my vee too! Miss the bite?
Yeah,I´m not used to it yet,so I don´t know how much I need to pull the lever to block the wheel completely as with vees it was really on/off only,I kinda like the modulation and smoother feeling though.
How does the headset work? I have bought the same, but have read some bad reviews about them..
Nice bike. Looks like a good and stiff setup
I have it on for two weeks only so can´t tell much about reliability.It works fine,no creaking or play and it´s smooth so I can´t complain about anything yet ;) Thanks.
