Helicoiling Snail Cam Bolt
dann2707
My snail cam bolt hole on ones side of my Rockman Manus was fungled up before I bought it.
What size is the bolt? Is it the same size as a maggy bolt? So does that mean I need an m5 helicoil kit?
Completely new to this so sorry if it's a newbie question haha.
Cheers!
I knew that'd get mis-interpted. I didnt mean 'you' as in you dan, i meant as in people in general :)
Oh right I see haha, Sorry :badger:
you could drill through the weld surely?
I could, but it's not exactly ideal and i'd have a gash looking bolt sticking out of an otherwise sexy looking frame :P
I'm just going to helicoil it. Easy enough just wanted confirmation on what size but i've found it out now. M5 x 0.8 helicoil x 1 Dneeded.
Interesting to know that you can specify how big the helicoil thread will end up determined by the x 1d at the end, 1 D is x 0.8 so it will end up at 0.8mm long thread.
If you were to choose M5 x 0.8 x 2D the thread will be 0.8 x 2 so the threaded insert will be 16mm long. Useful information incase anyone reads this in the future like.
As the snail cam hole depth is tiny as cheesecake I need the smallest insert size ( x 1D)
It happened in Leeds one day, cause there's no thickness to the frame where it screws in it just got torn out by the wheel.
When you sort it, can I have my washer back in exchange for the original echo washer!! Lol
in that case, id be tempted to drill and tap it completely through. i run an stock x-ray where the snail cam bolt hole goes completely through the frame, and its been fine for the last year, and i run some pretty high chain tension!
I don't think you'll be able to tap it out as the hole won't be deep enough for the tap. As most taps have a pointed end with no threads
However I'm not 100% certain, i don't know how deep your hole is...and you may be able to buy a tap with out the pointed end.
By the sounds of it you'd probably be better drilling all the way through and using a bolt. but make sure you use knurled/toothed washers to stop the wheel moving aswell.
Do you have a video for that? ;)
  • Like 1
Dan, don't bother getting a tap or a helicoil, just get 2 M6 x 10mm cap heads and liturally screw them in. Will take a bit of elbow grease to do, but you will tap the hole with the bolt itself (the hole is already the correct size to tap to M6 (Y)).
Cheers,
Josh.
  • Like 1
