Chain Skips
clerictgm
with those tensioners you can remove the pin that sits against the mech hanger to allow it to sit against the frame. To lock it in place, remove the mech hanger bolt, then remove the alloy washer/spacer and replace with a thicker one and now when you tighten the bolt it will lock the arm in place.
