Rohloff tensioner
AkuskaUK
try replacing the jockey screws with longer ones an put a washer each side of the jockey wheels
Thats what I done years ago and it was perfect for the 2/3 years I used it
Just use a bit of thread lock on the bolts as they tend to undo themselves
When i used one I didn't need to replace the bolts, I just added some washers and used the spacers that came with it. It only needs a tiny bit of space, the screw bolt has extra on the threads, and the clip bolt has a washer on that you can swap for a much thinner one.
