Brake problem
Canardweb
Hello everyone,
I have a problem with my front HS33 brake. It's a post 2005 version. It's basically new, has been used several times bled with water. But lately after a new bleed and several rides the lever started not coming back after I press it.
I tried rebleeding it with a syringe to push the piston into the lever body back at the maximum and then do a regular bleed.It still does it. I tried changing the slave cylinder. and it stil does it. So I am sure it comes from the lever but I don't know what to do, tried rebleeding, putting oil or grease on the plastic cylinder inside the lever body, and nothing worked.
Please help me!
Have you ever got that problem? Any picture?
This literally happened to me a few weeks ago. Sand then piston down a TINY bit. When I say tiny, I mean tiny! The slightest over sanding can make your brake leak. Just do it via trial and error. Sand it, does it fit? No? Then sand it again until it does, little by little!
You could also stretch your spring a little bit as well while your at it.
Edited by dannytrialskid
