Chain tensioner help
bagre15
Can I adjust the chain tension on spring tensioners? Any better tensionin solution for a 2013 w/ 22/16?
Yes you can, but it´s hard to do with the chain in place. Take the chain of the freewheel so it´s loose, set the tension, put the chain back on. Problem sorted.
