disc mount sprocket
scousertrials
This kinda thing? I'd steer very clear of this personally, although some people have used cable ties before on a sprocket and it has worked but that was to make a rear freehub into a fixed one so they could run a ffw.
You would have to turn the hub around so the disc mounts are on the drive-side, providing it's a fixed hub, it could work. No chance if it's a rear freehub though.
That's also completely unrelated to what he's asking.
It's certainly possible if you drill the appropriate holes a suitable sprocket, but in most situations there's probably a better alternative.
Can you tell us why you want to do this? That particular bit of information will likely change a lot of people's response.
Its because my fellow rider has stripped the ratchet in his hope Xc hub. Hes to stingy to buy new hub. I just wanna know if it will rip apart when big power is applied.
Is he also buying a front freewheel?
He'll be running a fixed gear if not.
No-one will be able to tell you for absolute certain if it'll hold up since no-one does it, but I personally feel it should hold up for most things.
Edit: What Nick said. Forgot about the whole Hope-being-awesome thing.
Edited by aener
Send it to Hope, free replacement. (well, was when I f**ked the 4 Hope's I've owned in the past)
I doubt you'll get anything for free. I also doubt they'll repair it. I have an old Bulb hub which I stripped the ratchet ring on and subsequently contacted Hope. They said they no longer manufacture or stock the ratchet ring for that product but if I was to return the hub they'd sell me a Pro2 for £70.
I imagine they'd offer your friend something similar.
I must have pulled the right strings I guess, I had 3 pro2T hubshells crack on me (two older non reinforced, one newer reinforced) and stripped a ratchet ring on another and never paid a penny apart from postage and my own wheel building costs.
Maybe they stopped that though.
When was that though? I think they've tightened up their warranty procedure on account of people taking the piss.
I imagine Sam is right that if it's a currently made product they'll sort you out.
They did mine too, but I could definitely understand them not replacing things they don't make/have any more :P
