Axle bolts sticking?
isitafox
I bought a replacement axle for my Echo TR hub a few months back and ever since I fitted it the bolt fitment has been awful, after about 1cm of thread each bolt goes really stiff and you struggle to screw it in. As a result the only way to get the wheel out or even adjust it is with 2 allen keys as you need one in a bolt to hold the axle still whilst you unscrew the other, any ideas as to what is causing this??
