Cams
ginge
Need some help I have a Koxx sky 2 and I have snail cams in it at the moment... And everytime I ride the bike and kick hop or hop onto anything the back wheels moves no matter how tight I do it and then the chain loosens and falls off!! And it's sooooo annoying!! Can anyone help!!
Make sure the axle is not butted up against axle washer when tightened(had to file a few axles down due to frame dropouts worn slightly) and echo steel notched cams worked for me at least on on drive side and smooth on other for better tuning of wheel centre
  • 4 weeks later...
As long as you are able to get the axel bolts tight the only other thing you might want to try is a snail cam with a more aggressive notch on them. Adding notches with a grinder will not offer much more grip then standard smooth cams. Check out our notched snail cams, there is no way they will slip. The notches have been designed to wrap around the cam bolt.
Edited by isitafox
Advertising link removed
