Gearing! A bit too easy for street...
ChrisBrown81
Hi, I've recently bought a Onza Zoot for a bit of street/trials but I'm finding the gearing just a bit too easy. Currently running 18t freewheel up front and 14t at the back. I'm wanting a little more bite and a little more speed. So my questions are, what is everyone else running on 24" wheels and what do you recommend changing mine to get what I require? And could I just change the freewheel up front? Thanks
Does no one find 18/14 just not enough? I don't know if it's because I'm nearlly 15st that it takes more force to push me forward but when I'm wanting to drop off (if that's the correct term?) When I'm on the back wheel hopping and want to use a qtr turn of the cranks to push me forward while hopping it's like there's not enough force there? Maybe it's just me and I need to get used to it then.... I just wondered if anyone had,had similar experience and had changed thier gearing..
Edited by ChrisBrown81
Almost certainly it is a fixed rear sprocket. If you're lucky it'll be a splined one that's quite easy to get off. Most likely though it's a screw on sprocket that might be hard to remove. If so I'd recommend the tarty bikes method:
http://www.tartybikes.co.uk/media/guides/maintenance_freewheel_and_sprocket_removal/m1.html
Zoots run 175mm cranks as well
the sensation you are describing i'd say is down to the 175cranks. i would give 170mm cranks a go.
I've just had this on my mod, where I had to run 175mm Try-all experts (the same crank as onza zoots, owned both) cos thats what I had spare, swapped to some monty belaeys (stated 175, actually nearer 170mm) and it transformed the feel. Gave the effective feel of more engagement, put my arse n back higher in the air because my feet were closer together - (it's like you have longer legs) which in turn gives greater control on the back wheel because you place your body weight better and gave heavier gearing feel all because of the shorter stroke. It was faster cranking about too.
Plus, and I did this on my inspired, ditching the zoots for some trialtech sports and a different bashring (highly recommend a tarty full ring) saves a butt load of weight from the centre of the bike, really noticeable on spins I've found.
Edited by CC12345678910
