magura rub only when wheel goes backwards
bikeperson45
That is pad wobble on slave cyl prong/pin. The front edge of the pad will be sucked towards the rim when the wheel spins and you end up with effective toe in on the pad, whether the cylinder is set square or not. You need new O-rings (if CNC backings), new plastic backings or if like me you're still using std magura O-ring clamps just adjust the slave to cancel out the toe in..
OR you have a loose/less tensioned spoke on the opposite side to the pad that's rubbing. Find it, could even be 2 or 4 holes away from the rub, and tighten it 1/4 turn. With me on the spoke key this usually completely cheats pad wobble.
