Someone Help Me Get These Monty Grips On
roozor
Use hairspray, and put the grips on, so they have a bit of overhang.
The roll the ends up (like a jonny) then shove the plastic caps on, then roll the grips back over the plasic caps. It takes some doing!
^_^
I soak mine in water and slide them on, easy as pie and they dont take long to dry.
Ditto. I find that after I've slid them on, I've sorta wrung all the water out anyway so I can ride with them anyway. They just set straight onto the Pazzaz bars I've got, although I used some GT-85 today for them. Didn't seem to work too well?
For me, I just bosh my standard metal bar plugs in. Tried, trusted...
Mark.
P.S. Seeing as it's done, I'll lock it.
This topic is now closed to further replies.
