Azonic Bars
Martin
I rekon you Should get some onza carbon risers as i use them and they are shit hot. i have the 28" long ones which are good for street as its easier to x-up etc. if you do more natural get the 30" long ones as ballance is a lot easier i find.
:turned:
Answer pro taper bars is all you need to know.
Azonics snap and Eastern ea50 or ea70 bend.
Answer pro tapers are about £45.00 from crc and imo are the best riserbars out there.
answer pro tapers have a bare a striking similarity to ea70s (Y)
I prefer the easton vice bars over the ea70s :turned:
mike
depends wether you want high bars or low.........if your not sure go for a happy medium like 1.5", you can always put spacers under if its too low, or remove some if its too high.
Thanks Ali, will probbaly go for some 1.5's then, never thought about using spacers :P
