Is My Bike A Piece Of Crap?
omgnoseat
Well i got my first trialbike a a couple a weeks ago and ive ridden it for 12 days now, and some stuff already broke:
- chain (fixed now)
- broke 2 spokes (1 in front wheel and one in rear wheel)
- front brake broken (leak in the cable)
Keep in mind that i can't do any large gaps or drops, i only do backhops and small sidehops.
The bike is second hand but still..i dont think that things should break this quickly cus its quite an expensive bike.
And i never drop it or something too.
http://img12.imageshack.us/my.php?image=te...bikezors1ds.jpg
Now my question is, is it normal that things break this quickly or is it just a piece of crap?
- chain (fixed now)
Normal :) Everything breaks in trials! Plus with your bike being second and it will have had extra abuse even if your ant all to good... Just keep upgrading old worn parts every so often and with some luck they wont break..
Hope this helps...
Craig
Edited by Echo_Scotty
It's probably just a run of bad luck. If that happens every week then yeah, you could start calling it a piece of crap. These things happen, just replace the broken bits and get on with it.
P.S. If your chain has broken, it would be sensible to replace it rather than mending it. It's pretty likely that if it's broken in one place, it'll break again.
the chain wasnt really broken in the way you mean, it just suddenly stopped working, but its fixed now (Y).
and thanks for the replies because i was kinda worried that it was a piece of crap, because its hard to get replacements for trialbike parts in the netherlands
Don't worry about it, alot of people think that it is advanced people who break their bikes by doing insane gaps and such things. But I think from my own experience that when you begin trials you break things really often. When I started I was breaking my bike to bits.. it's normal, probably to do with exerting so much force on cranks and brakes etc. After a while you'll find all you need is a light touch and your bike will only brake a few times a year. :)
Haha, I was wondering why your brake levers were the wrong way around. Yeah your bike will just constantly die until you stop riding, it's trials, get used to it.
yea i think i will get a new one when i go to spain this year, they have lotsa trial stuff there :)
and i think ill check out the trials park in barcelona too (if im any good by then :rolleyes:)
When you start riding you WILL break stuff - and like someone said, after a while you learn to ride more smoothly and softly, absorbing all the impacts. It puts less strain on the bike; one thing that you have to learn is that it's not the BIKE landing hard that breaks stuff - it's YOUR WEIGHT landing hard on the bike. Trust me, it took me some time to learn this, but when I did, breakages stopped almost overnight. Whenever you attempt something, over-compensate (even if you think it looks stupid, it doesn't), absorb every impact with your legs and arms, and always think 'smooth'. Attempt to get every move as smooth as possible, don't just try and get as high as possible. Often the two go hand in hand - the techniques used to get soft landings are the same ones used to eek that extra bit of height out of yer machine.
Just my 10p. Hope it helps.
And yeah, I had a second-hand Monty that went through all the breakages you described, and then some. I sold it because I thought it was shit, then when I got my next bike I realised that it was MY TECHNIQUE that was shit and promptly started over-absorbing every move I did. My 'bike budget' dropped massively.
Edited by Jez
aha i see, thanks for explaining (Y)
You don't need a "trials specific" chain, just use the strongest chain that you can get from your lbs. KMC kool's are good, but if you can't get your hands on them you can just run a normal(still prefarebly kmc) bmx chain and it'll be strong enough, if you replace it every 4-5months or so.
nothing less than exquisite.
looks pretty light to ride, and montys are reliable frames atleast. just ride it.
It is what you treat it as, call it a piece of crap, and it will be, ride it and itll be the best bike in the world.
Thanks Jez for explaining it like that, im actually going to start riding smoothly now
Si
i got another problem with my front bake now; it doesnt work when i just press it, i need to keep pressing repeatidly do make it work.
i think this means that i got leak because there is oil all over my front disc too.
am i right or is it something else, and what can i do about it?
Sounds like a leak to me. Its a magura disc, so maybe try sending it back to them as they give a 5 year leak cover warrenty thing i think.
Otherwise, buy an Avid :P
instead of sending it back, is there a way too fix it too?
I got no papers or anything about the disc, because this is a used one, so sending it back wont work =/
Edited by Meteor~
