Help Me!
trials_pimp
Right, ive just been majorly attacked by spyware.
and I cant get rid of it.
Ive run ad-aware 5 times, and it still finds things that it cannot delete.
Ive tried to manualy delete them, and it says they are running, but the spyware has disabled task manager so I cant shut things down.
I have to disconect the Broadband cable or I end up with shit loads of ads and tool bars.
how di I get rid of this shit?
im getting things like Freeprodtb and Coolsearch
Ad-aware can get rid of them and its killing me. They keep rearranging things on my desktop and startbar, and stopping me accesing whats needed to get rid of them
HELP!!!!1
that probably won't work
it sounds like you've got something similar to CWS (don't worry too much, you probably won't lose any data)
check your default homepage URL in internet options - it probably points to a .dll file or something else weird - if it looks normal (ie. ends in html), set it to default - this should make the URL look weird
do a google search for the name of the file in your default homepage - this will probably tell you exactly which spyware/trojan you've contracted and hopefully furnish you with something to remove it.
if not there's a possibility you'll find some weird named folders in
C:\Documents and Settings\YOUR NAME\Local Settings
later versions of CWS squirrelled their shite away in much harder to find places than that so i wouldn't be too hopeful on that front
good luck
and don't enter any credit card details till you're rid of it
yeah- Cool Web Search- google it, there is a special program some guy wrote just to remove this. i had it and it crippled my old computer, took a week to get it sorted. unfortunately, the guy got fed up of rewriting the uninstaller every month to keep it up to date with the new versions of CWS, so it may not work if you have a new version.
i think the program is called cool web shredder or something. good luck!
Also, to stop programs running (making them unshutdownable) boot up in safe mode, then run antivrius/adware.
right, ive got ad aware, spybot search and destroy, spyware doctor, hi-jack this and only ad aware can find it, and it cant get rid of it, if you find the file and try to delete it manualy it says you cant, and we just run registry doctor and it found 16 registry faults.
this is gay and it wont disapear
Right, it turns out I have to have special drivers, as standard ones dont work.
Yea my PC started out as a parkard bell.
Anyway, thats sorted, but now Outlook is being gay.
It wont accept one of the passwords for one of my e-mail accounts, keeps saying its wrong.
But that very same password works if I manualy check the e-mail through the site, and it used to work on outlook
Switch to firefox as well. That will stop you getting as much spyware.
I remember using IE on my friends laptop on a fresh windows install and managed to get it totally crippled by spyware within 5 minutes :(
As for removing it try Adaware, Spybot S&D and hijack this.
