How To Fit Olives?
Alan
After spending ages trying to set up my brake i squeezed it and saw water dripping i checked the hose and theres a tiny slit about -> _ <- long.
Is there anything i can do apart from get a new hose??
I was thinking a bit of superglue on the hole then wrapped in electrical tape, Will this work?
PLEASE HELP! Cheers Alan :(
Edited by T-MAGura
After spending ages trying to vset up my brake i sqwueezed it and saw water dripping i checked the hose and theres a tiny slit about -> _ <- long.
Is htere anything i can do apart from get a new hose??
I was thinking a bit of superglue on the hole then wrapped in electrical tape, Wil this work?
im pretty sure you could sort somthing with super glue ;) if its only verr' small then it should be fine.
Dont bother with superglue, it will jsut split again under pressure. imagine being on the rear wheel on a ledge or something, the hose splits again and you loose the brake! could be painful. don't mess, the split will just get bigger, buy a new hose. Don't forget to use new olives when installing it!
No need to mess about trying to patch your hose, (providing it's at one end of the hose, such as lever or cylinders). Just unscrew it, remove the olive, then trim your hose down to just below where the slit was.
Slide the "screwey in bit" on your hose, then slide the olive on after that, then just screw the bit in, and tighten it up.
Good to go. :)
I was just about to make a topic about not being able to fit the olive then i saw this at the top of the page :P . It should just slide on mate, make sure that the hose is smooth at the end. If you need to cut it with hot sharp stanley knife that will get you a nice edge (Y) .
