Rb Levers ?
shucksmith1
Advantages:
Good lever feel and extra power
Disadvantages:
They WILL leak, needing to be topped up every month or so.
The solution, get someone to machine down the lever blade so it will fit in a 04 body. Giving you the extra power and good lever feel without the leaking. (Y)
i bought an rb lever and sure enough within a couple of days it started to leak. i took it apart and it looked like shite and grit got behind the first seal then scratcted the pistion bore thus letting the fluid leak out. so in the end i took out the lever blade and a file and put the lever blade in my maggy 04 lever body. ill try find a pic for y'all (Y)
IPB Image
Edited by scott-mad
IPB Image
Do you reckon that the rb lever blade would fit in the new HS33
Why pay 60 odd quid for a lever that leaks within a month or so pretty much waste of money if you ask me.
Whats wrong with the 04/05 standard levers
the 04s have a habit of snapping( once on a rail and once on the edge of a drop with me) saying that i dont particulary like the rb design ones. if only they made a lever to hopes standards.
Things I enjoyed about my RB lever.
1. It leaking.
2. It leaking some more.
3. That ball bearing.
4. It leaking.
5. The lever blade tearing the arse out of the seal on my standard Magura body when I fitted it.
6. The crap lever position/feel of it on a standard body.
7. It leaking originally.
8. Oh, and it utterly raping the inside of Magura cylinder.
f**k yeah. Buy one again in a heartbeat :rolleyes:
1. It leaking.
4. It leaking.
As you can see, Mark's real keen on them :P
Dude, there is apsolutely no need, Buy some vees! :lol:
