Gearing
Tom Booth
Im thinking of changing from 22-18, to 20-16. To improve my chainline, because most road cassettes come with 16tooth as 3/4th gear, and dont have an 18 tooth in there.
And I have noticed that 20-16 is a tiny bit harder...
22-18=1.2222222
20-16=1.25
Will this difference be noticable?
Im running 175mm cranks if it makes any difference?
Cheers
Tom
It's a mere 2.2% change.
And it's slightly harder gearing, so it'll match with your might long penis cranks.
I'd say go for it, plus you'll have a much lighter setup which is not a bad thing.
(Y)
unless you suffer from retarded legs it will make sod all difference
Just try it and if its not good, use and 18 again.
You do realise you can move the cogs around at the back to get a better line
Yeah, but a cassette that runs 12-13-14-15-18-16-17-19 Wont really work well....
Will it?
Tom
my god, I rode 22:19, then got my bash machined down so then I was on 20:17, but thought that was too harsh so went to 20:18, I found that to be perfect, try it out.
20:16 is just plain stupid, far too harsh
No its not ash! until a couple of weeks ago i was running 20:15, then nick gave me a 16t sprocket, so i am now running 20:16. it is better, but i dont think i would like to go much lower. i like harsh gearing for some reason.
