Monty Spray !?!?!?! Help
Infurnass
I done hot soapy, with tooth brush. Then scouring pad, didnt work.
Will try white spirit but would it remove my paint ? thats why i aint tried it yet.
I dont think that white spirit would remove the paint because it's one of the chemicals that paint consists of, although dont take my word for it. (Y) However as said above, you're best off using the 'Sticky Stuff Remover' with the link given.
Edited by Joe_Kearney
nail varnish remover migh twork, strong as f**k that stuff.
Pure alcohol should also work.
White spirits wont work
He's right. GT85 should also work as it works a treat on getting the sticky goo left on after stickers/carbon proptector patches and it doesn't damge the frame either.
What about that Hope muc-off stuff, meant to be be quite good.
Yeah there was a review in an MBUK issue about that stuff it was rated ok, if I root around and find it I'll scan it in and post it up, but my rooms an absolute tip. Its worth trying if all else fails.
Muc off
I don't think that this is the hope branded stuff but its pretty similar, can be used for virtually any bike cleaning tasks, and completely safe to use. (Y)
Hi
I used to use that rubbish it is basically glue and it forms a glaz on the pads which then stops them working properly. but the answer to your question is either Use :-
- Wd40 spray and rub off with a cloth
- gt85 spray and rub off with a cloth
- Hairspray spray and rub off with a cloth
- hairdryer to heat the glue up and melt it and rub off with a cloth
- A glue dissolving solvent
- Deodorant
Hope this helps
Robert
No muc off will remove resin. Soap won't work either. Use a nitro resolvent (will deal with it quickly) or petrol.
This won't remove the paint if it's been baked and lackered. Been cleaning frames with petrol ever since I got my first bike and no paint has ever come off.
Plus petrol smells really nice and you can burn it if you have any left over which will make you happy. 3 in 1.
