Grinds On A Wheel
Callum Trialsin
I dunno how many it took, but in a period over about a year and a half, my Ronnie had paper thin sidewalls.
You'll know when it's on it's way out 'cos it'll dent t'fook and then the dents will crack along the apex of the fold.
Then the metal will break off.
Then you'll die.
Surely it depends on the rim?
no i mean if the rim spins ---> that way
then will a clockwise ----> or anticlock wise <---- grinding action get you better results
because someone said on a ride the other day my brake works better backwards i think i did the grind the wrong way round i didnt really understand but im grinding my new rim tommorow tommorow so just wanted to check
Then you'll die.
Or just stop bouncing and jump/fall off. Andy manged to destroy his sidewall on tuesday and it wasn't really anything impressive... he'd been doing hefty rolling gaps for the best part of the afternoon and must have just hit it exactly on the dent that was already there. He just seemed to get off the bike look at it and then before you could say "jack robinson" he was on the phone to tarty sorting out a new one.
My rims had about 12 grinds on it.. However my grinding technique is very light and is about 1/4 of the normal grind destruction. When it happens it happens, just ride it till it goes.
EDIT: If you grind you're rim clockwise on both sides then they are both ground in opposite directions kind of so it'll give you a braking surface thats good for both forwards and backwards hold.
Edited by Krisboats
Ok cheers i might as well have not worryed anyway ill just do it normally lol thanks
