Double Disks
Echo-Scott
:S Sorry if I'm a bit behind the times... but dont the rotors just snap when your running a rear disk?
Cheers
No, not the rotors, the main problem was the frames snapping because of the massive force placed on one side of the dropouts. However, bike companies finally realised this and started beefing up the drop out areas and adding extra braces and gussets at the critical areas.
Hi, I was just woundering if there are any mod frames that can take a double disk apart from monty's???
Thank You.
Scott. :)
Scott why are u wanting a new frame you've had your echo a month, if that. Sorry about my post not being helpful in relation to the thread I just wanna know why u want a new frame already.
Edited by David20
Scott why wud u want a frame that can run double disks, you couldnt afford to get a new frame, new wheel, new disk.
Your frame at the moment is about a month old, ur an idiot
Fight, fight , fight, fight, fight.
You must admit Scotty you have only had the frame for a month so posting this up was pointless.
Don't really see the point in getting a double disk frame when your Echo ride very nice and that's coming from a big wheels rider. Hahahahahaha.
Cut the kid some slack, he could be just curious or wanting a future investment. Woopy shit he has had his frame a month, he could be hating it but I dought it.
Calm down and not use have text talk and half normal in your posts (Y)
Well you dont know this boy i do, i used to ride with him until he turned into a little willy, i know he likes that frame and set up as he has progressed quite a bit since getting it.
Pratically the whole set-up is new, waste of money to change
I'm not wanting a new frame i was just woundering if there were other frames that had double disks apart from monty's because I've never seen other frames with double disks.
mine :S i rode with you a few time and it can take double disc (Y) its a bit weird your not wanting it but you and david have both posted about it, and you both ride together.
Although now that they've got their acts together and beefed up the tabs, other parts are probably going to start breaking. The Simtra has super strong disc mounts, so much so that calipers/rotors are breaking instead of the tabs. Supposedly, a Simtra team rider has snapped three Avid calipers while riding it, while the tabs are still rock solid. :D
