Boosters
T-OM
Thanks for all the posts guys, i have now decided that i will go for a czar or zoo booster (Y)
sorry i thought ther would be loads about boosters on the search.
i am getting a 2 zoo boosters how do you fit them i dont now because im a newbie and i have never had one before what do they actualy do.
thanks
dan
thanks
dan
its very simple the booster comes with extra long screws and spacers, all you have to do is put the spacers above the clamps then line up the booster with the spacers then screw the bolts in (Y)
they stop your frame from flexing outwards when you brake (if you want to see this go run outside/or where-ever your bike is, and look at the rear maggy and pull the lever like a beast and you'll see the frame bend outwards slightly) so you brake feel stiffer (Y) and is stronger because of it, it also protects your crossover and looks pimp!
you install them by removing your bolts from the mounts then putting the longer bolts back in with the booster and spacer on as well it's prety obvious what you've got to do, it's just fiddly (N)
