Inner Brake Cables And Magura Hosing.
Andeee
i' never actually tried it before but in theory it should work unless the hose is thiner than the brake wire your trying to put through it
Adam
I was planning to buy a stainless steel inner brake cable then get a magura braided hose and run it on my bb7 am just querieing if it works anyone tried it?
Cheers Andrew
spongy as a water soaked stoat!
Right ok?
Well basically i just wanted to see if i would have a better front brake by running a inner cable through a hosing ive noticed these fibrax cables are a bit similar with the hole space and snuggness to run a cable through.
Andrew
Just get a Odyssey Slic cable. You're not doing barspins, so I don't think a linear is necessary.
Outer brake cables have a metal coil, whereas Magura hosing is simply thick plastic. Obviously the metal is a lot harder than the plastic, so it'll be stiffer.
So, as said, it will be horrible.
Don't do it.
i had a braded hose and when i tried to get it bled the shop couldn't do it
not sure why though never mind
jack
Maybe they didn't have the facilities or know-how.
Not every bike-shop will be able to bleed Magura's. If they're a Magura specialist, then i'd question why they couldn't do it too...
