New Echo Rim Brakes
Onza-rider
The performance may be just as good if not better but:
.It is cnc so its gunna be stronger
.It was specifically designed for trials in mind so its supposed to clear you ankles from catching
.Comes with echo brake pads
.Echo cnc mounts
All it needs is a braided hose and i would of considered <_<
I think il just stick to Maggy's though :)
.Tom.
i have rode a bike with them on, they are not all they are cracked up to be. My mates already had problems with the levers and adjusting the brake, also they come with the new echo pads which definatly need a grind to work to there best. They look at lot nicer than maguras but you can't go wrong with the maguras. Hope i helped
i think they're lame and a waste of money.
its just a machined version of the maggie so it might feel stiffer maybe lighter (though there probably won't be much difference anyway)
and you don't need braided hosing on a maggie, its pointless as well.
stick with the old maggies!
steve
Magura with long lever, water bleed, prefered pads in cnc'd backings, braided hosing, a cross over and that would do me. £135 is so much and considering the reviews have already been partly negative it just sucks. If the brake was all what i wanted plus a booster and cnc clamps then yeah it would be worth it.
