Drilling My Front Echo Rim
Sutty22
My front rim is the machined echo rim (as shown in the pic). I've noticed a few people have drilled their sidewalls and stuff and was wondering about taking some material out of my rim. I was thinking about cutting out the slots that are machined in at the moment. The question I have is, Would the weight reduction be worth the effort and loss of strength. I'm not particularly hard on my front wheel but I haven't gone crazy about weight anywhere else on my bike. Any pros and cons anyone has would be gratefully received. Cheers, Sutty
I would drill the side walls, I wouldn't cut the squares out, but you could drill holes in the middle of each square? Biggest drill bit I have is 13mm though and you would have to take the spokes out.
Drill and countersink each hole in the sidewall of your rim. I would drill where each spoke is, and in the middle of each pair, but mark it all out first orit looks all wierd. Then countersink them all.
Then you would have a half echo 05 rim, half Onza Hog.
I would not touch that rim with a drill. The 2005 models were weak I found, I destroyed one in 3 weeks. Dented in 3 hours of having it. A mate of mine snapped one completely.
What a front rim? I could understand a rear but no-one dents a front rim.
Drill it. (Y)
You having a laugh.
Beau Forrest said "These rims were the strongest rear rim i have ever ran, mine had 5 flat spots, 16 dents and it has held 6 grinds and is still going strong to this day. Hasn't needed a re-built or owt. However this was over a good 12 months of solid heavy riding. It did eventually die but what do you expect."
These rims will last a long time on the rear. My front one never gave me any trouble either.
I wouldn't say drill it on the rear but deffo on the front.
Danny.
You having a laugh.
Danny.
^^ What he said.
You having a laugh.
Danny.
Well actually no, he's not having a laugh, he is DEADLY serious.
Seems there were some cnc'd Echo rims that looks idential which were strong, and others which were wank.
I had a rear and dented it on my first ride, sold it to a mate who put it on his front wheel and dented it again.
Feel free to call me a harsh rider or whatever, but you'd be oh-so wrong.
So to actually answer the question, drill the centre of the squares and you'll be fine.
Errr, no you wouldn't. I've never taken the spokes out when doing it, and thats with a 16mm drill bit.
Be safer to take the spokes out incase you go through the rim quicker than you expect and managle a lot of them. My friend did this however he used a 20mm holesaw I think.
To be fair, i didn't even take the wheels out the frames/forks when i did them :$
The man speaketh the truth, they were notoriously weak, or at least that was the TF trend at the time. I would say drilling the sidewalls is fine, but dont go anywhere near the squares.
I dented my front rim on a pallet, so it can be done. To be fair it is a hog with the drilled sidewalls.
Well in that case, drill it.
You either fell off, or messed up, you can't dent a front rim just tapping on stuff. I only bent my wheel slightly when I was trying to learn to tap. It when very wrong and I went over the bars.
I'm out of this thread, I would drill it every time but clearly other people think I'm wrong.
