Front Vee
sidehop
Right,
I am going front vee because they have modulation and i prefer rim brakes.
But i now want to know...
1. Pads
2. Smooth/grind.
3. What actually comes when i order it from the tart.
Ill explain...
First up..
Pads Damon advised me to get crv's which sounds good but i wanted to know what you all thought. I looked at rock greens aswel.
Second..
I would prefer a smooth rim but that will depend on what pads i run.
Third..
On the picture on the tart site is it just the arms that you get or do you get a outer/inner cable. Lever etc etc etc...
Any help would be a godsend.
Chizz xx
This topic might be helpful to you, I was asking about vee pads too.
http://www.trials-forum.co.uk/forum/index....howtopic=102958
I've bought the Salmon ones but I haven't had a chance to try them out yet.
I think when you buy the brake on tarty or anywhere else you just get the arms, hence why levers and cables are available separately. Can't see brake cables on Tarty actually... maybe I'm wrong...
Yeh crv`s are mint i run them :) , you wont like them if you dont like your brake on or off theres no in between they stop dead every time.Thats on a smooth rim.
If you grind it will solve the problem but might not hold aswell.
