Theres So Many Front V-brakes!
cai
hi,
im building a 20" bike at the moment, and im looking for a front v.
what combo of lever, wire, and brake would be the best for about £40 (for trials use, oviously :P)
thanks
cai
Edited by cai
hi,
thanks
cai
I have an avid sd7 with heatsink cnc red pads , xtr lever and flak jacket outer cable for sale if your interested?
sd7 lever, sd5 arms, standard cable and plazmatic crv pads on light grind. so powerful and mint. ***!
it actually peeled the vee mounts of my mates urbans :o:O lol
matt
sounds decent matt, apart from the peeling of the threads :olol, i think i'll go with that!
thanks for the help so far guys.
sorry mate, ain't intrested.
as long as you tune it correctly anything will be suficciant personaly i managed wiht some avid sd3's for a long time before upgrading down grading 2 hs33s
vee's rock. end of.
more hold, easier to set up, lighter to pull the lever, more reliable.
why would you want magura's? the hoses snap easy, so you have to get braided hose.
harder to set pads up straight, because there is two bolts to hold the cylinder. i always found mine moved slightly and the pads wore wonky.
magura's have less hold.
get some an avid sd7 with sd7 lever (Y) with plazmatic crv's on a smoooth rim
damon watson use's pretty much the same set up (i think he uses sd5 arms?) and his brake is stupidly powerful.
