Drilled Rims..
=)zoo python
Most just use a file but it takes a long time but I think its a bit pointless to be honest are you wanting the squares for the look or to loose weight?
The look :P, im not a weight freak to be honest.. I just want to run black squared rims, white rim tape, black spokes and a black hub
Meh real men drill their frames to save weight ^_^
Lmao, Did you? Any pictures?
Never done it, but everyone uses a file.
If i was to go about it, I'd drill out the 4 corners, then use the drill to remove as much material as possible then finish off with a file.
I was thinking that sort of thing..But i'd be scared of cocking it up. I will have to find someone who does it or has some for sale. I think they look really good with squares, how much do they weaken the rims? It's for a mod if anyone was wondering.
Well, it shifts all the stress to the corners. will crack eventually and probably collapse the wheel.
People who do it, tend to change rims alot. i think it was benito ross that used to do it.
Like the zoo! crashes video? the guy collapses his rim which is squared out.. Don't want that:P Can't afford to be changing rims alot.
Think it was the echo 05's ? That came with squares. Trials-uk have hexigons. But yer people do use files, makes the rim weaker.
They were milled out though, not holes. :P
I cba with it, I've got a double drilled Onza Hog rim on the front, looks the dogs.
you can actually get square drill bits ,they are used to put square holes in wood.its like a drill bit with chisels that make the hole square.
steve
A mortice bit?
Dont think it will go through metal like. ones ive seen is a drill bit inside a sqare tube with teeth at the bottom.
