Is It Good To Weld Up A Frame When It Is Snaped
bradnutter
yes mate that will be fien get it done proffesinally and it will hold
dec
wrong wrong wrong
If you just get the frame welded up, no matter how well its done it will snap again with in a matter of months or weeks. Trials frame are heat treated and when a frame is rewelded from cracking the heat undoes the heat treating makeing the frame weak around that area.
What you need to do is weld it back up and have it reheat treated the frame should then last. Heat treating can be expensive though.
welding a frame as far as i am concerned is fine. i have just had my own frame welded back up after it snapped. it was done professionally and they also put an extra piece of metal onto my frame to try and increase the strength a bit more.
So it is fine but i would just suggest you get it done by a specialist ^_^
Non of this will make a difference unless you heat treat it, a bracket welded on will help but eventually not solve the problem, people have had frames welded and it snapped a week later below the weld because they didnt have it treated.
Hey, i cracked my orange zero at the chain-stay. my mates a welder by trade so i got him to weld me it. I had a plate welded on and a load of weld built up around the crack. Within weeks the cracked developed again, and it is bigger now than ever.
If i were i would keep your eye out for a new frame, maybe a second hand one. I don't think its worth the risk of injuring yourself if the frame was to crack or snap again, especially if your doing something big. And you'll always have it on your mind when trying something that there's a possibility it could break again. joe b
Was always of the opinion if it's alloy it just isn't worth the cost and potential hassle of having it welded due to, as others have commented, heat treatment process that all alloys frames go through, steels a different matter as it can be welded back up without too much hassle but even then I would still be cautious riding it. Whenever I have broken or cracked a frame I've always binned it as don't think it's worth getting injured over it, but sucks not be able to ride ebay is your friend start looking for a new frame. ^_^
Depends how bad the snap is, if it has bent other parts of the frame it won't work too well I would have thought. My mate got a Monty PR welded when it cracked, and that was fine up until he sold it, I think it was heat treated.
Best to ask in a motorbike shop, as they often have to get frames on motorbikes welded if they get one in with damaged lugs or cracks.
welding an aluminium frame without heat treating it is never going to be as strong as before...with proper heat treatin it would, theoretiucally, be the same strength again...but the likelihood of finding someone to heat-treat it for a resonable price is fairly small!
