Echo!
Matthew_Gibson
Spec:
Echo control 2004 short
FSA Orbit Equipe Headset
Viz forks
Deore front brake, CNC backing and heatsink reds
Avid SD7 levers
Avid SD7 rear brake, Coustsink in CNC'd backings
Viz
Tarty grips (soft)
Echo stem
Rear wheel - Hope Pro II, Echo 07 rim,
Front wheel- Hope XC, Mavic D521
Echo cranks
DMR V8's
SKF BFR-300 Bottom bracket
KMC thin chain
From the other of your double posted threads:
iLike. Hope to see it in Bristol soon to compare notes :)
edit; can't keep away! How are you finding the dual vee setup?
Pretty good. Wheel needs trued up its a bit off. like an inch !!! feels a bit heavy too. needs set up better. Fit the booster, fit new rear tyre. new pads on the rear, and its good to go!!
