Magura's
c.j
They also lack in power due to having a smaller piston, they often snap do to its plastic construction. But if you buy an hs11 and just change the lever it becomes a hs33 :)
They lack power because they have a larger master piston, and a flexy composite ( plastic ) lever with an alloy blade
However; an hs33 lever with hs11 slaves = hs33 brake......although 04 hs33 lever body + hs11 blade = absurdly powerful brake due to increased leverage
HS11 lever, on an HS33 lever is good for leverage, but the lever blades are plastic...so they're spongey and snap.
but if the levers are cheap enough and they work twice as good it might be worth it
this answered my question and more! :D haha
And how the f**k have you managed to do that then ? My HS 11 lever would %100 not fit in an 04 body, there was no way in hell :S
Also, they did have the Magura logo on them :S
Wtf..
