Maggies And Water
leeW
Hi,
Just a quick question.
I was watching an interview with Ryan Leech on you tube and he mentioned about how he used to use water in his HS33's.
He said it used to give him less "spongyness"when riding.
Is this possible, or do you HAVE to use Magura brake oil ?
Any help on this will be very welcomed.
Thanks.
Iv never used water i use hydraulic fluid in all my bikes but i use Morris LHM plus hydraulic fluid its a fiver for one litre and my brakes work very well.
But some of my friends use water it works fine so its up to you.
Edited by Earl
Whats the difference between LHM Plus and a standard DOT 4 fluid? Was there a reason why you went for LHM Plus over other hydraulic fluids?
Just seen that LHM is a mineral oil while DOT 4 is a synthetic fluid. Does that mean Maguras need a mineral oil brake fluid?
Ta
Edited by eep803
Thanks for all your thoughts guys.
I will prob just try both and see which i prefer.
The hs33's that are already on bike are filled with oil b ut wil change to water and see what happens.
Thanks again.
Lee
Ta
Maguras use mineral based fluid thats why i use LHM Plus.
